21 - 26 of 26 Posts
Automotive tire Gear Motor vehicle Rim Engineering
If this is TDC then you out by abit ,about 90 degrees.
I have the stock cam and tried to copy the above pic.
Here's the pic.
You need to rotate the cam 90 degrees clockwise to look like these pics.
This is how it should look at TDC
I hope this helps.
Yea it's at tdc in the pic and I dOnt get it really. Like u said u gotta have hub right because it's keyed and I didn't take rockers out at all. So don't understand it. I've rotated and checked timIng several times.
if the hubs on right then did you put the bolts that hold the sprocket in the wrong holes? the cam needs to be facing correctly like the pics baxter put up.
Discussion Starter · #23 ·
Ok Bike is done. And problem was my idea of cam lobes facing down and the correct way were not the same.. Pics done me wonder Baster thanks.
21 - 26 of 26 Posts
