1 - 13 of 13 Posts
I torqued down my head bolts to 49pi/lbs as per manual shop specified and it leak... I used a cometic gasket and did'nt used any kind of cooper glue on it. The head and cylinder has been surfaced as well. With a 11:1 piston do I have to torque it more , let say 55 pi/lbs?
I just fired mine up and its not leaking, same piston.
Yeah it bubble enough to over flow and well after an hour and it's not overheating the fan kicks in like before. I check the compression and it get 105psi. Tomorow I will open it cause I found some lil piece of rubber like on the cometic gasket
the sleeve droped .013 in the cylinder... so the gasket popped trought a water passage .For your it has been resleeved. I so angry I think I'm gonna k.......?%/?&?$*&*
Discussion Starter · #11 ·
Ok guys first of it's ultimate performance from quebec that done it and I trusted him when he told me that it's gonna be less expensive . I have orded my piston before opening the engine and found out the sleeve was too worn out and cp don't list an oversize piston :(
1 - 13 of 13 Posts
