OK! After 20 years of working around jet engine, you would think that I should be very proficient on bike engine but nooooooo! I'm replacing my throttle to a twist one and need to remove the carb since I do not have enough space between the frame and carb to remove the plastic cover. The problem that I have at this moment is how to disconnect the air hose, looks like an 02 sensor hose. Any help is greatly appreciated. Also beside the dealership, where can I purchase a manual.
Thank you.
Thank you.
