We are having problems with the bike starting when cold and for some time after it goes.
when it's cold 90% of the time its a real bitch to get started... it acts the same as jumped timing. it will back fire out both the exhaust and air box. It will even shoot flames out the exhaust. then after cranking it off and on for a while it will start and run fine.if it should stall it takes a little to get it to start.
but then other times it will start fine and run great.
I have checked and adjusted the values also the compression(80psi) and it's still a bitch to start.Also a new plug.
is there a way to check the FI. sensors ? could it be a crank sensor?
Thanks
Shawn & Kyle
2008 700XX
Thanks
Shawn & Kyle
2008 700XX
