I change mine at 10hrs max, and there is a very good reason to change it often, I guarantee you your oil breaks down long before you will hit 30+ hrs. it is cheap insurance for a high cost investment that I want to last...but to each his/her own.i did mine at the first 20hr then at 100hr next in gona do it at 200hr or when the oil gose black. no need to change it every 10, 20, 30 hours like some ppl do thats just a waste of time and money i cand spend riden.
ditto... why risk causing engine damage when you can just change the oil a little early. Generally I'm every 4-5 rides (couple hours each usually)I change mine at 10hrs max, and there is a very good reason to change it often, I guarantee you your oil breaks down long before you will hit 30+ hrs. it is cheap insurance for a high cost investment that I want to last...but to each his/her own.
Same hereI don't change my oil on a set schedule. Everything depends on what kind of riding I've been doing.
So whats your point?, none of those are wet clutch applications and the oil does not provide lubrication to the tranny as well.cars go way over 100hr with out new oil and they have o lot more moving part... same with boat engines and they live at 6000-12000 rpm and tractors go over 1000 hr with out new oil and the live in dust. and there air filters are shit.
Yes tractors are wet clutch but they do have good filters and pre filters.So whats your point?, none of those are wet clutch applications and the oil does not provide lubrication to the tranny as well.
I thought that tractors that utilize a wet clutch used the hytran fluid and not the engine oil. Not saying you are wrong, I just hadn't heard of it.Yes tractors are wet clutch but they do have good filters and pre filters.
not as good as atv's ohhhh and boats dont have air filters.Yes tractors are wet clutch but they do have good filters and pre filters.
And how often do you drive your boat in the dirt?..again your point?not as good as atv's ohhhh and boats dont have air filters.
