When you are looking at your shocks in the front, you will notice two nuts at the bottom of your spring. You will have to use a screw driver or something of the sort and a hammer to loosen up the lock/jam nut (which will be the one on the bottom) loosen that and than adjust the other one down as well until you get your desired height, and you should have the same adjustment on both sides. Measure it w/ a tape measure. Then retighten the jam nut so it wont move at all. These nuts are as big around as the shock, just look near the spring. These are not the ones that holds on the shocks to the frame.
