Wow, that was a lot of work. I hope that these things end up working. Tires are BKT, 19" dia fronts, 18" dia rears, I ran a bailer belt inside the rears, and slimed them, no tubes. Screws are kold kutter. I don't know if the pattern will work, or how best to index them, so I did straight up for now and will adjust later.
The rear tires lowered the bike about 1.75", I have nerfs coming, and the 11/16 sway bar coming.
I was thinking about taking the short "helper" springs off the front shocks to lower it another inch- they're in compression just sitting, and I don't think I'll need it for the ice since I'm not jumping, I was also thinking about doing limiting straps on the front A-arms to keep the front end down. I've seen some lower shock relocation brackets for other bikes, and will do some measuring to see if they'd work without having the shock hit the A-Arm.
In the rear, I was looking at relocating either the upper or lower shock mount to get her down more.
