as most of us get that chain to tight using the cams on our honda trx700xx. we need to find a new way to adjust the chain. eather we need someone to make a new set of cams with more ajustment to cater for that inbetween setting we need. or some thing like bikes use. a thred road and a nut.
a plate made that fixes in place of the the bolt our standerd cams use that as the numbers scale plate, some thing to fix to the main bolt to line up the numbers both sides. and a way to pull the rear back it the thred rod and nut.
or we find a set of chain cams that are out there on another bike with more settings overs a greater radius cam
some thing like this may work
http://cgi.ebay.co.uk/SNAIL-CAMS-CH...em&pt=UK_Motorcycle_Parts&hash=item2555bf5d80
then add a pointer insted of the bolt head we have at the moment
any ideas i did ask l8ton racing as he seems good at making things for our honda`s
