ok..have the PCV all the way installed exept the wire tap. what whire do you connect it to? it says in the install guide to hook the wire tap to the yellow/blue wire, well there is a brown/black, brown/yellow, brown/blue and a black/blue wire...which one do I hook it to?
by the picture in the manual it is connected to the second terminal from the left which would be the brown/yellow wire (I am assuming it is this one to connect it to) however I just wanted to make sure first.
