steel ? naw, alloy, yes...They are steel !
It is different than the 450R. The 450 is much smaller. Not sure why, but probably due to the fact they assume you will change the oil much more in the 450.but its different to a trx 450r?
I don't know about the 400ex hubs but the 450r hubs will not fit on the 700xx knuckles. The 700xx uses a thicker spindle. alot thicker.Tried it !Do front 400 EX Hubs fit on a front of a 450r? If so they must work on the 700xx!
The crankcase oil and transmission oil are separate in the 450R. The crankcase side is filtered and holds less than a quart of oil.It is different than the 450R. The 450 is much smaller. Not sure why, but probably due to the fact they assume you will change the oil much more in the 450.
