However, these are for FRONTS only and would not be set up for your weight... as in ordering them from Houser or Elka direct.
Just to clarify, these will be set up to your weight, even states in the auction they will be built to your specs. When you order Elka shocks from a Elka dealer, they pass on the info directly to Elka, Elka then builds the shocks and they are sent to either you, or to the company you ordered from and then they ship to you. I have owned three sets of Elka's in the past, and even though I ordered them from a different Elka dealer each time, they still came from Elka. Unless you are buying used, a Elka shock should always come setup for you.
Yes, this is a good deal, but like Roadkill says, You may or may not need the extra adjustments. I also saw listings for the same setup with compression only and compression and rebound for cheaper. I have ordered a few things from ATV Galaxy and have never had a problem, good prices and has always shipped fast, but I do agree with Remingtonsteel, see what Wiigstyle can do for you, since he is a site sponsor.
