***Disclaimer - Using this method will disable your stock engine kill switch
This is the K&S Kill Switch I installed: http://www.bikebandit.com/k-s-kill-switch-tether-line
*Note - Any "Normally Closed" kill switch will work
Tools Needed:
Phillips head screwdriver
scissors
wire strippers
soldering iron
shrink wrap
electrical tape
Estimated Time: 15-30 minutes
Step #1
On left side of handlebar, locate stock engine kill switch. Unscrew (2) phillips head screws on back of assembly. Pull apart assembly. Using your scissors cut back wire loom to expose the wires and allow easier access to them.
Locate wires to stock engine kill switch - Black wire with Green stripe and Black wire with White stripe. Cut and strip wires.
Step #2
Cut (2) 1 inch pieces of shrink wrap. Using solder and soldering iron, tin blk/green stripe and blk/white striped wires on harness side. Mount Kill switch to bar and tin the 2 wires from switch. Solder wires from switch to the blk/green wire and blk/white wire. It does not matter what wire u attach, they are not polarity senitive.
Step #3
Wrap wires with electrical tape very well. Mount stock engine kill switch assembly back onto bar. Turn key and start your ATV. Pull the tether to see if your engine will shut off. If operational tests are satisfactory, then you are ok :yay:
Tools Needed:
scissors
wire strippers
soldering iron
shrink wrap
electrical tape
Step #1
Step #2
Step #3
