I haven't been riding much, or had the time or location to work on it. :/
Going riding this weekend with Jeff (5w0p3) though!
Oh good, I can relax now..... :nuts:That was it - valve adjustment and it purrs like a mountain lion!
I can appreciate good sarcasm.Oh good, I can relax now..... :nuts:
I can appreciate good sarcasm.![]()
It has gotten me in trouble more than once.OK, accidental sarcasm.
Yes I have tried, and tried, and tried.:steamed:Maybe you just need to go over the K.I.S.S. concept with them?
Keep
It
Simple
Stupid
tried that first.i agree with the idea of bypassing the controller, you may find even that when you cahanged the map im guessing you had to pick your controller up, you may have a pulled a wire loose, if bypassing the controller works, check all the pin connections for loose/bent pins, if bypassing works and you have no loose pins is it easy to change your map back, caus you may find something went wrong with the download, im guessing that the controller takes a few sec to perform a slef check and it will run while doing this and if it has a fault it will shut down
