I'm probably the only one that hadn't found this out until recently. I'm sure Baxter and the others that race alot already know but I will post it anyway.
When you stall the old girl you can slide the thumb switch to off then back to run and she will fire right up when the warning lights go out. If I don't do this mine is real hard to restart and usually coughs and spits for a few seconds when it does start back. IDK if this resets the pcm or not but it does run the fuel pump again just like a cold start. Seems to be the ticket on mine anyway.
Hope it helps someone sometime.
