1 - 16 of 16 Posts
your pics didnt post or i cant figutre out how to open them!:atv:
very nice! yeah you save a lot of $ how much money was the material? and how does it run? you may need fuel controller now to add fuel.:atv::xx::rock::tup:
you can see in your pics how corked up the cannister is from the oem and you saved a little weight back there too!:xx:
And the header i built it in bigger
So i save a lot of Money :)
Very nice looking job, :tup: What size diameter did you make your header pipe?
43mm and 52mm
is 15% more as the stock i mean
Nice! What size front and rear sprocket did you end up running to help with high RPM's at Wide open throttle?
that header looked fatter than the Barkers!:atv::hey:and the powerbomb.::hey::hey:
18 Front and 35 Rear
WOW! Are you running with any type of speedometer with tachometer? I was wondering your rpm's at like 70mph/112km/h. Certainly a lot lower than with the stock 14/37. And I bet your top speed has raised as well! But wow a 18t front, are you still able to have a case saver on?
1 - 16 of 16 Posts
