1 - 5 of 5 Posts
How do you remove the lower ball joint? Without the special tool???
Sent from my SM-G930P using Tapatalk
  • Like
Reactions: blakjak619
Break the nut loose and the either place another nut on top of it or loosen the nut so it is near the top of the threads then strike it with a hammer to break it loose.
Has anybody found replacement ball joints for the front of a TRX700. Went to shop and they said Honda only sells the hole control arm.
That's true.
1 - 5 of 5 Posts
