maps
ok does eny one have a map for an fmf powercore 4 slip on a k&n air filter with an efi programmer
Ok where the hell is everyone gettin their k and n's from? Because I called k and n not the distributer not a dealer, K and N and they said they don't even have a listing for the xx. SO which filter are u guys using?ok does eny one have a map for an fmf powercore 4 slip on a k&n air filter with an efi programmer
Ok so this modquad deal is the coupler a step up or down piece from the filter to the tb or straight piece? Cause if its a diff size then maybe the filter is for something else anf just being made to fit with a coupler?I use the modquad setup. Comes with a K&N filter, outerwear prefilter, and an aluminum coupler to hook it up. It was about $120 and worth every penny.
Ok, now we're gettin somewhere. Thanks for checkin. Now just for ur own satisfaction, you may want to follow thru on this and find out what filter u actually have. Cause I'm thinkin its for a different application.I just went and took off my filter. The bottom of the filter has F045A6 but the top of the filter has B045A6 and K&N's website dose not pull up either number![]()
I doubt its actually pieced together outside of K&N. K&N themselves may be using pieces from previous models to make this universal filter.I guess it may not matter as long as it flows the right cfm for the engine. But since the part numbers on the top and bottom don't match and they don't come up on the search at the k and n website, maybe someone is piecing this filter 2gether and callin it "k and n". Oooohhhh the plot thickens!!??
