Grease your steering stem, check brakes, check ball joints and tie rid ends for wear, check chain and sprockets, check valve clearance, maybe clean out the radiator while you got the plastics off, flush coolant and refill with new, check brake fluid, adjust clutch, new spark plug, maybe clean the throttle body and intake tube, clean air filter, oil change and filter and clean oil screen, check cv joints for wear.
These are just some things to think about checking over the winter. I'll think of some more.
