1 - 13 of 13 Posts
is there a kit (pivot works for example), to replace the small bearings of the rear wheel hub? (between wheel hub and arm). Or should you buy the original part directly and separately?
Administrator
If me, I'd by the OEM bearings. But I'm sure there are many aftermarket companies selling them.
OK thank you. If someone has a reference for these bearings so that I compare the rate with the OEM. Here in FRANCE, I can’t find a reference for these bearings😔
Administrator
Administrator
Thanks, but it’s not that bearing. It’s the little bearings between the hub and the arms.
You'll have to be more specific, there is only one bearing in the rear hub assembly. Are you talking about the sleave, that the long bolts go through?
Administrator
1 - 13 of 13 Posts
