Something that may help, I took mine to a machine shop, and got them to put my shocks on a milling machine. They milled the the top mount down to the thickness that i needed. Each side is the same thickness from center, and both surfaces are completely square. If you take a little more time and do a little more trimming with the grinder, you dont have to take much off of the 700's mounts. All I had to do was make the radius on the back and front a little wider (maybe a 1/8" if that). Then went back touched up those places with paint. Put a polishing wheel on the Dremel, and polished out the places on the top of the shock. Looking at it close up, you cant tell that those shocks aren't factory.
