Same thing I deal with. If I drain the tank,crank case and change the filter I just put 2 qts back in it and never had a problem.Oil level is something I fight with on this bike. I change my oil by the book and it's at a different level every time I check it. My 450R was consistent and was always at the same level. A honda tech told me to quit worrying about it as long as there was oil on the dipstick.
Same here 2 qts. I mean wth are going to do with the 0.1 qt left over anyways?Same thing I deal with. If I drain the tank,crank case and change the filter I just put 2 qts back in it and never had a problem.
Wow! That's just shy of 2.7 us qts! Is it full yet!last weekend i put 2.5 litres
Nope just make sure to drain the crank case, filter and the main tank. After that just put 2 qt. back in it. Make sure it is for wet clutch and your good to go.When you change the oil is it just the engine or is there gear oil on the 700 as well?
