Ok
Started bike to go to start line ,a bit of popping and spluttering nothing to worry about . Started race and everything was running fine until lap 2 when entered woodland for second time . There were a few sra stuck on one corner and had to wait probably about 20 seconds and when I stopped I could feel the heat of the engine on my right leg , I lent over and could feel the heat on my face and the exhaust was blue. The woodlands were very tight and the clutch was used alot. Set off after waiting and 50yds further the clutch gained a serious amount of free play .Took 3 complete turns of the adjuster. the engine run fine in both the woodlands and fast bits.It seemed get through the rpms faster than normal .
All this would suggest a lean setting .
Anyway stopped at 2 hour mark for more fuel and noticed it had only used 5 or 6 litres which seemed off.
Filled tank up and set off for the last hour and noticed it stalling alot at low rpm in the woods , It would pop and die. It did this about 10 times per lap and I could not seem to keep the front end down and missed alot of corners due to this. I also noticed it sluggish at high rpm's and struggled after 3/4 rev in 5th.
I did 7 laps before stop and 4 laps after . On the last lap about 1/3 the way round it started to cut out and died like it was running outta fuel so switched to reserve and finished the lap.
I have not checked spark plug or how much fuel is left in the tank.
The air filter is full of dust and I ran the 14t sprocket which is going in the bin.
I am going to check the filter in the pump and change the clutch cable.
Thanks for any help
