1 - 6 of 6 Posts
can some of you post a pic of your Fassst Flex bars & clamps? I wanted to do the flex bars & retain the idiot lights. What is best way to go? Thats why I wanted to see pics..Too many choices..
Thanks
whiskey delta has them on is quad some pics in xx garage
I just put mine on yesterday. Trail Tech clamp and Quadracer 14 degree Flexx's. Pardon my dust, my 700xx is under construction right now...
Looks good Jamie.. How difficult was the install? Thanks
Really easy, probably the hardest part was getting the lights into the dash, and that was easy too. I already had the bike apart because I just checked my valves, and I should have my EHS programmer tomorrow. The ODI grips made it a snap, I highly recommend them! All of the cables reach no problem, you just have to break/cut off the cable holders from the stock stem otherwise the dash won't fit. Some people have cut the dash to keep the holders, but the way I did it should be fine. I'm 6' 2" so I think this setup will work good, the clamp is about 1" taller then stock and leans forward a bit. Can't wait to test it, especially when I get my desert seat. :D
1 - 6 of 6 Posts
