1 - 5 of 5 Posts
I have a 2008 trx 700 that when in lower gears has poor performance (revs really high before moving) but once in 3rd and up it has a lot of power. Does anyone know if this is normal?
Sounds like a clutch problem, either in the adjustment or worn out?
I think it might need to be adjusted bc it catches almost all the way out. How do you adjust it?
The threaded rod in photo is the clutch adjuster.
  • Like
Reactions: Killalltires
1 - 5 of 5 Posts
