Sorry I can't help you there. The Pro Design is a Normally Open circuit type kill switch and our quad is Normally Closed. Again, our quad needs an odd ball piece. I use a Gunnar kill switch and it's a Normally Closed type... Easy and straight forward to install... Only requires you to tap into one wire going to your handlebar kill switch... splice into this wire and connect the indicated wires from the kill switch to each side of the cut and ground the 3rd wire. All this can be done behind front plastics... outta sight. The inline connection allows both kill switches to still work.
Instructions to make a NO kill switch work for a NC quad can be a PITA and some require a "kit" from Pro Armor... But, guess what... Pro Armor doesn't make a "kit" for our quad.
