It is important when re sleeving the Honda cylinder to reinforce between the bore and the outter casting. From the factory there is no support between the bore and the outside perimeter of the cylinder. Most cylinders have some sort of bracing in the water jacket to improve it's structural integrity. We first mill pockets in the water jacket between the bore and the outside of the cylinder. We then press in cross drilled dowels for support. These dowels are cross drilled for water flow and welded at the top of the cylinder. We next bore out the cylinder and drop in the new 105mm sleeve. Then we bore and hone the cylinder to match our CP piston, and then lastly we deck the top of the cylinder to ensure a flat sealing surface for the head to mate to.
$629.99 with cylinder exchange, also includes 13:1 CP Piston
