1 - 12 of 12 Posts
· Banned
when iam flying down a dirt road it feels as if my rear tires arnt hooking up and the front end "dances" from one side of the road to the other and the back end slightly fish tails one side to the other, and i have to slow down to keep it going straight
should i....
widen the quad ?
dampner ?
razr tires ?
which of these will do the most in order to correct this problem ?
^^^^^ Bump think u r on the rite track Scuzz.
Yea that will make it act silly it has to have toe in to track strait.
i run 1/4 for a desert set up, least 1/8.
no more than 1/4.
Before you adjust the toe in check the tyre pressures are equal on both sides, then see if the quad actually feels like it goes in a straight line when the bars are ponting forward on a flat surface at low speed. You could also check the front wheels spin freely and that there is no brake binding or faulty bearing. If all is fine then have a go with the toe in.
· Banned
Discussion Starter · #11 ·
i do have a slightly bent wheel........ i keep forgetting this when i ride.... but it only seems to dance when i get into the loose gravle.... on a black top road or hard packed dirt road i get no danceing what so ever
1 - 12 of 12 Posts
