1 - 20 of 20 Posts
This is a couple pictures of my 6-ply Razr rear tire that got a puncture last weekend. This is a friggin stick that went right threw my tire and broke off leaving only a small piece stuck in the tire. I've got it at the tire shop now getting a patch and a tube put in it. Hopefully it'll last a little while like this as these tire's only have about 30 hours on them.
[/IMG]
[/IMG]
[/IMG]
Should have just bought a plug kit, could have fixed that easy, would not have had to even remove the tire form the quad. Would have had to use a few plugs, I think my record is 7 plugs to plug one hole! That was even a sidewall. Guy used the tire for another 6 months before they were so worn he had to replce them. Never leaked any air, plugs held fine.
I have to agree... some plugs should've worked just fine. My riding buddy got a tear in his sidewall and fixed it still on the trail with 2 plugs.
yep, plugs will work amazing, even on sidewalls, I have seen up to 10 plugs in a huge sidewall hole, held up fine. I would remove the tube as you will get a flat really easy, especially if you hit a rock.
of course they did they wanted your money lol. i say glue the stick in from the inside and outside looks like extra traction to me lmao
plugs are amazing, just be sure to use the glue w/ them, the rubber cement that is. I always carry some with me, you can get various sizes. I sold 700xxmaniac a tire with like 8 plugs in it, leaked a tad but that was right on the brim/sidewall which is the hardest spot to plug. My roomie has 9 plugs in his side wall and didn't trim them like you normally do cuz he is afraid they'd push in lol
Hi Red, mate you havent been Kenda Kuttered yet you beta ASAP, it will stop all the problems with the flats.
Overlord
Discussion Starter · #15 ·
I guess I just figured the stick would have broken before it went threw the tire? Don't get me wrong I'm not dissatisfied with the tire. This is the first time I've had a puncture on these tires. I am just wanting to give the kutters a try when these wear out.
If they plugged that it would look as thick as the stick poking out.
I bet that the tree actually started growing through your tire while you were putting on your helmet, gloves and goggles. :p
Red, a truck plug will fix that , I done the same thing on my first ride on the Razzar1's, I dont have to explain how good it is to have the Kutters not one flat in 10 rides, I am over the moon and now leave the plug kit at home.
Overlord
is that tube a HD tube with the metal locking valve stem
thats what I run in my fronts they hold up great if you pinch the sidwall on a rock more than likely it will not get the tube
1 - 20 of 20 Posts
