YES.......Is there a 10'' rim that will suit the 700xx and the 450r.
NO......Are the bolt patterns the same on the rears of each? Thanks
NO.......!.........the best tires for Finke would be the new KENDAS. Some people use the narrow tyres for desert as they say they are more stable at speed. That may (or may not) be true for them but the XX is heavier than most sports quads so it needs a bigger foot print. Also at Finke the bull dust can get so thick and deep that you will need the widest tyres possible to try and sit on top of it rather than cut through it to try and find hard ground.Ok fair enough, do you believe for something like Finke Desert Race that running fronts on the rear is an advantage?
You won some RAZR's.......:tup:..........use them for the year and do the race on the Kendas. Smitty tore up the MAXXIS and punchured them on Day 1.:tdown: the KENDAS weren't available.Yeah it does hopefully will be able to do it next year. I already have a 11'' razr's for the rear (won them) and rzr2's for the front and have a set of OMF beadlocks same as Smithy's i think. Are you doing safari this year?
