Well! As usual there's always some web site that will sell your info so if you want to remove yourself from that web site;
http://www.spokeo.com/
type your name under search and if you see yourself under your new or old address, click on the link then go to the main link above....where you usually type www.andsoon
copy that link then go to the bottom of the page and you'll see "privacy" on the lower right corner and click on that link and paste the previous copied link under the url and finish typing the info below and submit. You'll receive an email and just follow the instructions which is real easy.
Don't forget to check all the states that you lived in the past cause I found myself under CA, TN and PA.
