did we need a puller, or it's easy to pull it out?
WiZkY · Registered Joined Jul 22, 2009 · 172 Posts Discussion Starter · #1 · Jun 3, 2011 Only show this user did we need a puller, or it's easy to pull it out?
08700xx · Premium Member Joined Feb 28, 2009 · 2,487 Posts #2 · Jun 3, 2011 Only show this user You don’t need a puller to remove the front sprocket... Its easy to remove.
WiZkY · Registered Joined Jul 22, 2009 · 172 Posts Discussion Starter · #3 · Jun 3, 2011 Only show this user Thanks pass to 15t this weekend
08700xx · Premium Member Joined Feb 28, 2009 · 2,487 Posts #4 · Jun 3, 2011 Only show this user you’ll have to remove the case saver or grind it down a little so the 15t will fit.
WiZkY · Registered Joined Jul 22, 2009 · 172 Posts Discussion Starter · #5 · Jun 3, 2011 Only show this user it's done, I drind it a little bit!!!! around 1/16 to 1/8
