ayone know were i can get a set of 4 itp ss rims rocky only has the fronts but i want them all the way around and i want them to fit kend bear klaws 23x8-11 in rear and fronts are kenda bears klaw 22x8-10:thanks:
Was that you that posted some pictures of the ss rims? If so can you add link to post, and if not post a picture? 10" tire on 5" rim probably balloons out a lot and no way to rub rim, unless you really try.just buy four of the front rims. that's what i had to do and is works fine I have 10" wide tires mounted on the back of my xx on the 5" wide rims no problem.
