1 - 18 of 18 Posts
whats up guys im wanting to get a few inches of height on my bars if i got the rox risers and put some fatbars on there would i have to change out any of my cables.
depends on how high you go. the throttle will prolly need to be plus 2 inches.the clutch and front brake have a little more length than throttle, it would be a good time to upgrade to stainless steel cable intead of the oem rubber brake lines:xx:
really about 2 or 3inches is all i want to go i plan on getting the rox risers and some renthal fatbars with the trailtech plastic that is 7 bucks i stand and ride alot so id like to have it so im not slouched over so much when riding
Contemplating the Roxx myself. I am 6'7" so extra height is needed.
Is there a recommended longer throttle cable? Place to buy the stainless brake line?
Part of me wonders if 2" is enough. I'd hate to extend stuff to have to extend it again. I want to make sure the sit/stand transition is easier as I like to stand often.
Also curious if the dummy lights just push out of the plastic dash piece. I am going to Fab something up but don't see how they are mounted
Ok, found the manual on here. Answers my second question, figure in case someone searches I'd post the answer.
"Remove the indicator lenses from the indicator sockets by prying them with a small flat-blade screwdriver.
Remove the indicator sockets from the handlebar cover, then remove the handlebar cover from the handlebar."
I was trying to hard...
2007 TRX450ER
I use the rox pivoting risers with the stock cables and brake hose but it is maxed out.
I found a mod quad dash plate on ebay for about $23 and it is great. If you need pics I can get them.
2007 TRX450ER
Photos sent to your cell.
Thanks. That thing is sweet. I designed something similar to hide the lower mount, but for $20 that is a no brainer. Off to ebay!
Have you tried calling Modquad direct? That's how I ordered my last 2 pieces from them.
Ha, the internet has ruined me. Never thought if that. Friend of mine bent me a piece which I hope will work. We will see here in a week when I get back in town
I ordered longer cables tonight. Stock ones could almost take the 2", but not where I want to put the bars. Still need a stainless brake line. Any recommendations?
Just got the notice the Streamline brake lines landed, I have the motion pro cables, and my Elkas should also be at the house when I get back from Germany. Woot. Will get a garage night in here and have a completely different machine.
1 - 18 of 18 Posts
