1 - 7 of 7 Posts
i just got a second hand alba fuel controller yesterday and it didn't come with any instructions. i know what the different modes are and how to add or subtract the fuel amount but how do i make sure that its set at least close to bein right? i know that you can go put it on a dyno but there isn't any close to where i live. I have a stock air filter (probably fixin to buy an uni) and a 2 bros exhaust. can anyone tell me what i mode and fuel mixture i should set it on?
:thanks:,
Garrett
:xx:
they come stock ready for a pipe and filter, i would assume you should have a decent map, until you get in touch with them, if your quad starts, idles and runs, take it for a ride and do the spark plug check, you know go wide open in 2nd, clutch and kill it at the same time and stop quick with the brakes, pull your plug and check the color, if you are a nice golden brown man, you're close enough until you get to a dyno...I wasnt actually aware that you can change the maps in them at all actually thats why i'm considdering the PC Instead
I am not sure about the Alba, if that is anything like a regular PCIII, I can send you a map so you can compare it. I got it from VelociRaptor about a year ago and ran it all the time until I got my big bore kit.
1 - 7 of 7 Posts
