Mine came with a 2 different size (thickness) washers. They are pretty hefty washers, not your typical flat washers. some are as thick as 3 quarters (money) stacked. And the rest are like 2 quarters stacked. Do these go in between the plate and brackets?
I also got like 2-3 small plastic washers too. And a whole mess of those brackets that go on the frame where the bolts go into them to hold on the frame. I'm seriously thinking of using some sort of thread lock on the bolts so they don't come loose. The last thing I want is one of my skid plates coming off while I'm riding. Could cause some serious damage to me and my bike.
As far as the rattling, I was thinking of gluing some kind of rubber or something between the plate and frame to minimize rattle. The kit came with some black foam pieces with adhesive backs, but I seriously doubt that they will last very long considering all the sand and mud I go through.
I'm one of those "visual learners" :nuts: so I really need some sort of diagram or pictures to figure this out.
If I ever come across some directions in PDF format of something on how to install these, I'll be sure to post it. Some how I doubt I'm the only one that could use some visual directions on how to install these.
I really appreciate your help. I'm gonna give it a try again tomorrow. I also have a LEXX programmer I have to install on my bike as well. Hopefully that should be easier to install and setup. Man I hope so....
Funny.....I used to be a auto/diesel mechanic.
hno:
Thanks!
Shonie
