xx-rated said:I already got my front a-arm guards from PRM, should be getting my Trail Tech clamp and Pro Tapers today! I got the Evo's (only $18 bucks more than the Contours) in the CR hi bend. With the Trail Tech clamp, the CR hi bend matches the stock height. Can't wait to get this stuff on, I HATE stock handlebar setups! Will post pics!
For your RPM did you just wrap the coil? What do you idle at? 760 something and it erratically jumps to 1100ish?0.5 is the setting for PPR. As for temps I am also wondering that question. Mine has been running around 210 putting around and it had hit a max so far at about 221. When I open it up it gets down to about 196-198 and this was on a hot 85 degree day with around 70-80 percent humidity.
I also notices that the RPM doesn't work perfectly all of the time on the Vapor.
Thx, I'll give that a try.I talked to the vapor guys again. They said that I should try and put the cable on the spark plug cable. He said to lay at least one inch of the cable flat on the spark plug wire and tape it on with some electrical tape.
