what do you mean change 2 tires in 30 min is that taking the tire off rim and putting different tire on the same rim? do the beadlocks make it easier to change the tire? ive never owned any beadlocks thats why im asking. i know bead locks are stronger and keep tire from coming off bead when flat but didnt know it speeded up tire changes.OMF beadlocks, worth every $$ when you can change 2 tires in 30 min.
Arms are houser racing +.75"About your a-arms how wide are they and how do you like them?
In 30 min, I can have two wheels with tires off the quad, remove the lock rings, break the beads on both tires, lube new tires, stick them on the wheel, install the lock ring, torque the lock ring bolts, blow them up to seat the bead and stick them back on the quad aired up and ready to ride.what do you mean change 2 tires in 30 min is that taking the tire off rim and putting different tire on the same rim? do the beadlocks make it easier to change the tire? ive never owned any beadlocks thats why im asking. i know bead locks are stronger and keep tire from coming off bead when flat but didnt know it speeded up tire changes.
How are you breaking the bead with the wheel still on the quad???Yes, that is breaking the bead. You never have to take the rim off atv. But you either need to be fast with a wrench, or have a battery operated impact.
