Go for it. It will lean oout some, but unless you hold it wide open for a looong time, you will be fine. Yep, the 2Bros pipes scream....
I did some mid 5th gear runs racing out on the sand. No popping, no backfiring, no issues. I do need/want a programmer. I probably wont be going out again until Jan 10th, so that gives me some time.
That looks killer! Real short...I like it!
Got any pics where it meets the header?
I spent 2 hours looking for a collar that I could slip on to the factory header that made up the difference. Discouraged and on my way home I stopped in AutoZone who hardly ever has what I need and low and behold, this time they did! I got an adapter that is 1.5 to 2" I cut slits in it so the clamp could hold it on both side. The adapter fits over the stock head pipe and the pipe from the slip on fits inside the adapter. Works PERFECTLY!
Man I know that thing must be ear piercing. I see it is repositioned in both pics, Is it permanent or you were still mounting it?
The first pic was temporary (before i found the adapter) The 2nd picture is permanent, when the clamp almost doesn't cover up the "Two Brothers" logo.
Yes. It's loud.
:yay::hey:
I think that looks better than the two brothers I have that is made for the XX. It is much shorter but is also larger in DIA. You can order Tips and spark arrester for that can I believe. If you can get a P1 and spark arrester that will bring you sound down to a tolerable level and make it less poppy sounding it also adds a deeper tone . That does look sweeet.
I would deff take a look at the plug to make sure you are not going lean.
Thanks! I think it looks better than the one they made for the XX as well.
Yeah i'll pull the plug in the next couple days. I know I need a programmer, but hopefully I can get one before Jan 10th. I'd be interested in getting the P1 tip and a spark arrestor - but 8" flames coming out are cool!
Pic from today -
