today i did some expierementing with my preload and i found some setting i like, i set my rear all the way hard,and the front 1/2 way soft. my reasoning behind this was because of my streetbike expierience, if the front drops in a curve it will cause the bike to respond because it drops all of the weight on the front wheels due to the front being softer than the rear, i adjusted the rear hard because i was looking for more slide. on a streetbike i run my rear only slightly harder than the front because too hard would cause it to wash the rear out, so i figured it would apply to a quad in a similar manner....the way my bike is now it transferrs the weight to the front tires under hard braking requiring me to lean off of the bike less to slide and take a fast turn and made it where i can take almost a 90 degree turn at the top of second which was impossible with my factory setting of everything soft. a fair warning is to not tighten everything to hard, i tried this first and found that it will flip extremely easy :disgust: luckily i saved it with only slightly soiled pants.im open for any questions
