Does any one know of a way to mod the steering to make it turn tighter and easier. I do a lot of woods riding and it needs help.
Best mods per dollars!:xx:I did the 11/16ths L8ton swaybar and 23" Maxxis RazR's in the front. Works pretty good for me!
If you purely want a tighter turning radius and have no push ,then get a TRX450r 2004 oem stem. The tree(?) at the bottom is longer . Not quite forklift truck tight steering but close enough.You can get an aftermarket one but some fit and some don't. The oem 450r does fit and t is about the same stem height.I need to decrease the turning radius for low speed turns.
