I have the shock and vibe bar clamp/mounts, a CCP damper and Renthal 7/8 bars. I don't want to switch all that out for an aftermarket antivibe stem. With the shock and vibe clamp vibe is no problem. I emailed Teixteira about a stem that had the stock bar mount and the same diameter as stock with just the flag repositioned to reduce bump steer. I figure I can use his upper a-arms and with this set up get real good handling without spending for new bar mounts, damper and bars. Anyone else want this?
