hi guys, i did try to search but found nothing on this. i recently bought this atv and on deceleration it ll backfire sometimes. atv is stock. what s the cause of this ? normal?
I recently purchased a ATV of a differant brand, that back fired when you let off of it. And after runing a few tanks a gas thru it, it was fine. So I wouldn't pull the panic plug right away!
should it be anything to worry about in cold weather? Like say.... around 20 degrees? I plan on runnin my stock xx this weekend for the first time, an it'll be in 20 degree weather.
I rode mine today @12 degrees.
knew someone that pulled the spark arrestor out of the stock muffler, and it would pop like that. He rode the hell out of it like that and the only problem it ever had was that sometimes, it would pop, and stall if you let off then right back on at low rpm.
