anyone had mesure the stock quench clearance with 11:1 piston? Maybe Smooth1 ?
Brokenbones · Premium Member Joined Dec 30, 2009 · 520 Posts Discussion Starter · #1 · Mar 3, 2011 Only show this user anyone had mesure the stock quench clearance with 11:1 piston? Maybe Smooth1 ?
smo0oth1 · Premium Member Joined Nov 14, 2008 · 2,932 Posts #2 · Mar 4, 2011 Only show this user No sir. Any particular reason you need it or just curious? I can make a call tomorrow to someone who may know.
Brokenbones · Premium Member Joined Dec 30, 2009 · 520 Posts Discussion Starter · #3 · Mar 4, 2011 Only show this user for you info:11:1 piston, oem gasket piston to head clearance is .058
boost addict · Registered Joined Jun 14, 2010 · 2,525 Posts #4 · Mar 4, 2011 Only show this user Good to know thanks.
E EHSRACING · Premium Member Joined Dec 10, 2009 · 708 Posts #5 · Mar 4, 2011 Only show this user i have measured quite a few with a 3 layer cometic the usually come out around .065-.070
boost addict · Registered Joined Jun 14, 2010 · 2,525 Posts #6 · Mar 4, 2011 Only show this user Eric... The stock vs Cometic was a .020 difference correct?
E EHSRACING · Premium Member Joined Dec 10, 2009 · 708 Posts #7 · Mar 5, 2011 Only show this user you can get a variety of them generally the 3 layers are .027 and the piston to deck is right about .040-.045
