Did some research, Found that if you modify the frame a wee bit, along with the fairings, and some vin number swaping (use the vin from a sport bike for the frame). Put signals, a horn, and street tires and boom your done. Next thing you do is go to your Texas DMV and ask for an "ASSEMBLED TITLE". This is where making the TRX look like a sport bike with 4 wheels is your best bet. The DMV personel will check out your "BIKE", the vin on the frame, and then make sure its all up to par for street legal laws. Then after that if you check good (which you should) they will issues a title. Once you get the title you can change it back to looking like a trx cause the hard part is over all you would have to do after that is tag the atv and your in good shape. In all, it would probably be a weeks worth of work, and then you can drive where ever when ever.:xx:
