Well, as I mentioned in the ice tire post, I split a lug on the outside rear tire, which ended my day. I cut the tire off and found that even though the lugs are only1/2" tall, the 1" long kutters I used barely poked through the carcass of the tire, and the bailer belt that I had inside the tire to help hold the studs was just flopping loose inside the tire since none of the studs were in enough to bite. I also seemed to pitch studs in only one set of lugs- the 2nd set in from the outer edge. The outermost lug started to split between the two outermost studs, but it only split about 1/16" - 1/8" deep from the surface and then was solid beyond.
So... I have a new tire with 1.250" long studs. The longer studs should bite into the belt with no problem (I think). I'm also thinking that I need to run lower pressure. I was running 12 psi- just enough that the tire had a slight crown, but since I ripped out studs only in one area- that was most likely the area doing all the work. I'm thinking a lower pressure would allow more contact and more evenly distrubute the load.
My finger is pointing at the missing stud area. The pic of the edge is hard to see, but the lug is splitting between the screws. Any suggestions?
