Why do the simplest tasks often become the most troublesome???
Ok, so I get my EHS controller installed and programmed - simple, easy, perfect.
Next, I go to install my new K&N air filter, which first requires removal of the factory air filter. Ok simple enough, I've only changed every air filter in every vehicle I've ever owned, should take less than 5 minutes, right?
Wrong! The stupud screw that secures the bracket at the back of the air filter seems welded on. Mind you this is a new 700XX with less than 20 hours. Of course Honda used a regular phillips screw that is now starting to get messed up cause it won't budge. I had even let some kroil seep in before I got started, but no luck.
Don't tell me some factory nim rod decided to use red locktite on that screw and now I may have to drill it out. :steamed:
