What does everyone think about running synthetic oil? I think im gonna make the switch.
Make sure it specifically says it can be used with a wet clutch. Other than that, it should be fine.What does everyone think about running synthetic oil? I think im gonna make the switch.
So if it says it has wet clutch anti slipping technology then it should be ok...and the Manuel says 10w30 it wouldn't matter 10w40 would it?Make sure it specifically says it can be used with a wet clutch. Other than that, it should be fine.
That should be okay. My local dealer doesn't even carry 10W-30. They use 10W-40 in all oil changes and new bikes.So if it says it has wet clutch anti slipping technology then it should be ok...and the Manuel says 10w30 it wouldn't matter 10w40 would it?
