Where do you set your air pressure at? I know the RAZR's need more air than the 6.1psi rating for the factory Dunlop's. But how much more? I do mostly VERY aggressive rough trail riding, some jumping when I can, drag racing, and some MX.
No..It's because they're a POS. If you're not bending them you're not riding hard enough.Could it be that most people with bent rims were running below normal air pressure?
just add 1 take 1 depending on condition. whoever said they run 8, damn.At Maxxis we always suggest running the air pressure recommended by your vehicle’s manufacturer.
Try that on the RAZR fronts and see how it handles. My brothers Z400 is labeled as 4 front and rear using factory tires. We set it 4 and trying to turn was like the tire was flat. It pushed and slid across the ground instead of actually biting, digging, and turning. Guess what we did.... ran them at 8psi and it handled perfect again. We also found that on his bike it felt the best when the rear RAZR's were at 7.5psi.duhh ths is wat u should do either way. just add 1 take 1 depending on condition. whoever said they run 8, damn.
