1 - 9 of 9 Posts
Did you cut the part of the metal brace that sticks out for the fenders or do something different with it?
Also I'm thinking of adding some grease zirks (sp) to my A arms. What would be the best way to do it? I'm thinking just drill a hole through the a arm only but that would only lube the outside of the bushing. Just want a little feedback from someone with a little more experience.
Cut them just something to go into you if you wreck!! If you want to be able to use them again, cut them weld in a smaller piece of pipe (brake line works good) then drill a hole put a small pin in it or a small bolt.
Left mine the way it is. Never had a problem hitting it. I'm also 5'8" if that makes a difference.
Don't think anybody will hit it riding.........it's that time when you have a naste get off and that thing ends up going in to your side!!!!
Are your knees worth $40?
I got lucky and only put a hole in my jeans and a gash in the skin on my kneecap. If I would have done anything to my knee I think I would have rather wiped my ass with the $40, lit it and ate it before losing a knee or risking surgery.
Just my $.02.
1 - 9 of 9 Posts
