1 - 4 of 4 Posts
Ordering a set of XC Masters for days when there isn't as much of a mud focus, but want to have a second set of wheels with some mud tires for when the conditions call for it. First trip is in 2 weeks and it is muddy so I need them somewhat promptly. I think after a lot of searching I've narrowed it down to one of three Bear Claws and the Zilla. These are going on 10" Douglas wheels. Not sure which option to pick.
**All specs from Dennis Kirk
Bear Claw 0.8" Tread:
24 x 11, 23.2" diameter 21.37lbs
23 x 10, 23" diameter 22lbs
22 x 12, 21.1" diameter 23.56lbs
Maxxis Zilla
0.6" tread: 22 x 11, 15.6lbs
I am not sure I believe the .6 on the Maxxis (mudthrower says .75") I am also having a hard time with the weight as they seem really light (mudthrower has the 22-10-9 at 15.2lbs).
Fronts will be 22" XC Masters for both the dry and mud tires. What would you pick?
The xc master tires will surprise you in muddy conditions. Of the other 2, I've ran claws but not zillas. Claws are good but heavy & there probably cheaper. If I were you, I'd run the gbc once, before you buy more tires, that you may not need.
Thanks. I also will use them in the snow so something with a paddle makes sense but didn't want to cloud the discussion as I would optimize them for muddy trails and deal with less than perfect for the snow. I live on Lake Minnetonka so while I primarily snowmobile, if I just need to get somewhere on the lake I will hop on the XX. I'll order up a set of the claws for that.
Well I know the Bear Claws will work in the snow, a lot better than the GBC Xc master tires. Speaking of snow, I'm wondering if you seen this youtube video?
1 - 4 of 4 Posts
